Omnia no-wifi (bought quite recently). installed an SSD and am booting a fresh 7.1.3 fine from that.
Installing banip requires the --nodeps options because of the logd clash, and it all works fine. What do I do about pkgupdate always failing because when it tries to re-install banip from the auto-list it fails because I can’t give it the nodeps option?
The banip in the repo is old, the fix would be to upgrade it in turris repos but not sure who to ping about it.
The workaround is to install specific / upgraded version, e.g. see this post: Turris OS 7.1 is out! - #56 by mazhead
