Ath10k_pci Direct firmware load error
I have found a problem with the firmware driver in the log. I have connected a “cat/var/log/messages | grep warn” and the second part of the log - if they would need to see the context of the. Have not noticed any real problem.
About what the problem is?
root@turris:~# cat /var/log/messages |grep warn
2017-02-03T07:58:29+01:00 warning kernel[]: [   20.024066] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
2017-02-03T07:58:29+01:00 warning kernel[]: [   20.034811] ath10k_pci 0000:02:00.0: Falling back to user helper
2017-02-03T07:58:29+01:00 warning kernel[]: [   20.053579] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
2017-02-03T07:58:29+01:00 warning kernel[]: [   20.063980] ath10k_pci 0000:02:00.0: Falling back to user helper
2017-02-03T07:58:29+01:00 warning kernel[]: [   20.159650] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
2017-02-03T07:58:29+01:00 warning kernel[]: [   20.170123] ath10k_pci 0000:02:00.0: Falling back to user helper
2017-02-03T06:58:34+01:00 warning odhcpd[2147]: DHCPV6 SOLICIT IA_NA from 00010001176fdb21ce5dc16ab83d on br-lan: ok fd35:11d3:9071::718/128
2017-02-03T06:58:34+01:00 warning lcollect[2244]: epoll_wait on 4 interrupted, retry
2017-02-03T06:58:35+01:00 warning odhcpd[2147]: DHCPV6 REQUEST IA_NA from 00010001176fdb21ce5dc16ab83d on br-lan: ok fd35:11d3:9071::718/128
2017-02-03T06:58:36+01:00 warning odhcpd[2147]: DHCPV6 REQUEST IA_NA from 00010001176fdb21ce5dc16ab83d on br-lan: ok fd35:11d3:9071::718/128
2017-02-03T06:58:38+01:00 warning odhcpd[2147]: DHCPV6 REQUEST IA_NA from 00010001176fdb21ce5dc16ab83d on br-lan: ok fd35:11d3:9071::718/128
2017-02-03T06:58:42+01:00 warning odhcpd[2147]: DHCPV6 REQUEST IA_NA from 00010001176fdb21ce5dc16ab83d on br-lan: ok fd35:11d3:9071::718/128
2017-02-03T06:58:51+01:00 warning []: Unable to use //tmp//yin2yang.xsl (No such file or directory).
2017-02-03T06:58:51+01:00 warning []: YANG format data models will not be available via get-schema.
2017-02-03T06:58:51+01:00 warning []: Unable to get tty (Not a tty) to get the client's hostname (session 5613).
2017-02-03T06:59:14+01:00 warning odhcpd[2147]: DHCPV6 REQUEST IA_NA from 00010001176fdb21ce5dc16ab83d on br-lan: ok fd35:11d3:9071::718/128
2017-02-03T07:05:02+01:00 warning watchdog[]: Restarted nethist
2017-02-03T07:05:02+01:00 warning watchdog[]: Restarted ucollect
2017-02-03T07:05:03+01:00 warning ucollect[8869]: Remote closed the uplink api.turris.cz:5679, reconnecting
2017-02-03T07:05:03+01:00 warning ucollect[8869]: epoll_wait on 4 interrupted, retry
2017-02-03T07:05:03+01:00 warning ucollect[8869]: Reconnecting too often, waiting a little while
2017-02-03T07:05:06+01:00 warning ucollect[8869]: epoll_wait on 4 interrupted, retry
2017-02-03T07:05:07+01:00 warning ucollect[8869]: epoll_wait on 4 interrupted, retry
2017-02-03T08:05:16+01:00 warning ucollect[]: Last message 'epoll_wait on 4 inte' repeated 1 times, supressed by syslog-ng on turris
2017-02-03T07:07:41+01:00 warning odhcpd[2147]: DHCPV6 REBIND IA_NA from 000300010011320d2cfc on br-lan: ok
2017-02-03T07:15:02+01:00 warning watchdog[]: Restarted nethist
2017-02-03T07:17:44+01:00 warning odhcpd[2147]: DHCPV6 REBIND IA_NA from 000300010011320d2cfc on br-lan: ok
2017-02-03T07:23:20+01:00 warning ucollect[8869]: epoll_wait on 4 interrupted, retry
2017-02-03T07:25:02+01:00 warning watchdog[]: Restarted nethist
2017-02-03T07:28:01+01:00 warning odhcpd[2147]: DHCPV6 REBIND IA_NA from 000300010011320d2cfc on br-la
2017-02-03T07:58:29+01:00 info kernel[]: [   19.412056] Loading modules backported from Linux version wt-2016-10-03-1-g6fcb1a6
2017-02-03T07:58:29+01:00 info kernel[]: [   19.419648] Backport generated by backports.git backports-20160324-9-g0e38f5c
2017-02-03T07:58:29+01:00 info kernel[]: [   19.841856] pci 0000:00:02.0: enabling device (0140 -> 0142)
2017-02-03T07:58:29+01:00 info kernel[]: [   19.847733] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
2017-02-03T07:58:29+01:00 err kernel[]: [   20.044463] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
2017-02-03T07:58:29+01:00 err kernel[]: [   20.073446] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
2017-02-03T07:58:29+01:00 info kernel[]: [   20.090416] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
2017-02-03T07:58:29+01:00 info kernel[]: [   20.099696] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
2017-02-03T07:58:29+01:00 info kernel[]: [   20.109324] ath10k_pci 0000:02:00.0: firmware ver 10.2.4.70.54 api 5 features no-p2p,raw-mode,mfp crc32 9d340dd9
2017-02-03T07:58:29+01:00 err kernel[]: [   20.179735] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
2017-02-03T07:58:29+01:00 info kernel[]: [   20.188664] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
2017-02-03T07:58:29+01:00 info kernel[]: [   21.331388] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
2017-02-03T07:58:29+01:00 debug kernel[]: [   21.421805] ath: EEPROM regdomain: 0x0
2017-02-03T07:58:29+01:00 debug kernel[]: [   21.421811] ath: EEPROM indicates default country code should be used
2017-02-03T07:58:29+01:00 debug kernel[]: [   21.421814] ath: doing EEPROM country->regdmn map search
2017-02-03T07:58:29+01:00 debug kernel[]: [   21.421818] ath: country maps to regdmn code: 0x3a
2017-02-03T07:58:29+01:00 debug kernel[]: [   21.421821] ath: Country alpha2 being used: US
2017-02-03T07:58:29+01:00 debug kernel[]: [   21.421823] ath: Regpair used: 0x3a
2017-02-03T07:58:29+01:00 info kernel[]: [   23.000994] u32 classifier
2017-02-03T07:58:29+01:00 info kernel[]: [   23.003710]     input device check on
2017-02-03T07:58:29+01:00 info kernel[]: [   23.007378]     Actions configured
2017-02-03T07:58:29+01:00 info kernel[]: [   23.380878] Mirror/redirect action on
2017-02-03T07:58:29+01:00 info kernel[]: [   26.010923] netem: version 1.3
2017-02-03T07:58:29+01:00 info kernel[]: [   27.203772] fuse init (API version 7.23)
2017-02-03T07:58:29+01:00 info kernel[]: [   27.381690] usbcore: registered new interface driver cdc_wdm
2017-02-03T07:58:29+01:00 info kernel[]: [   27.391175] Ebtables v2.0 registered
2017-02-03T07:58:29+01:00 info kernel[]: [   27.396572] ip_tables: (C) 2000-2006 Netfilter Core Team
2017-02-03T07:58:29+01:00 info kernel[]: [   27.474261] ctnetlink v0.93: registering with nfnetlink.
2017-02-03T07:58:29+01:00 info kernel[]: [   27.774486] nfnl_acct: registering with nfnetlink.
2017-02-03T07:58:29+01:00 info kernel[]: [   27.780169] PPP MPPE Compression module registered
2017-02-03T07:58:29+01:00 info kernel[]: [   27.785556] NET: Registered protocol family 24
i am having same errors (it was during the update/upgrade from 3.4 to 3.5 and 3.5.1 to 3.5.2 process. I mean it was just one time event).
Unless you have some serious wlan/wifi issues you can live with that.
It just means that the kernel couldn’t find the firmware file (-2 = ENOENT = No such file or directory) and then kernel failed back to user space helper to load the firmware. Those messages are normal for Omnia (standard WLAN version).
