Any mount kit available?
I just received a router, and I haven’t received any kind of mounting kits. Preferable the rackmount kit. There are no mouting holes on the chassis as well. I was in impression this is sorted out. However, I would like to order one, where can I get it ?
There was a separate mounting kit perk for Omnia available a limited time. Not sure if they plan to bring it back a later time.
I realized the same just when the router arrived :sweat:
So I hope they will release some details on how you could make one mountig kit yourself or make it again available … but I think they have more importan things to do right now
Or has anyone any idea how to make it at home?
i will be disappointed to if i don’t get them. I asked on a email and they told me holes should be there, and also kit to fix it
well, draft drawing is available at https://discourse.labs.nic.cz/t/omnia-wall-mount/560
