Hi
The original Turris OpenVPN Client package is useless to me for now.
I need to have:
- VPN tunnel for several machines in the home network with the Killswitch function.
- Internet without VPN for several other machines.
I read about:
- VPN Policy-Based Routing VPN policy based routing possible? + https://forum.openwrt.org/t/vpn-policy-based-routing-web-ui-discussion/10389
- VPN bypass https://docs.openwrt.melmac.net/vpnbypass/
Both packages above are by @stangri
It seems to me that none of them meet my requirements
(I think)
I went to pure OpenWRT and found the manual https://openwrt.org/docs/guide-user/services/vpn/openvpn/client-luci
but this configuration probably does not provide Killswitch either.
However, at the end of this original manual there is a link to https://openwrt.ebilan.co.uk/viewtopic.php?f=7&t=279 which probably describes how to get Killswitch to work properly without additional packages (firewall zone configuration only).
Now I have 2 questions:
- Can this OpenVPN configuration break something in my Omnia?
- Can you create 2 LAN zones?
LAN1 (with addresses e.g. 192.168.1.2 - 192.168.1.10) and leave it for VPN with Killswitch.
LAN2 (with addresses e.g. 192.168.1.11 - 192.168.1.20) and assign it to WAN without VPN.
