Hye everybody,
I have a broken cable between one of my antenna (I had the loose antenna problem)and the wifi module. Where can we buy this type of cable?
I looked in the market categorie but I think there are all sold.
Thanks
I found this but there is a lot of references… : https://www.digikey.fr/products/fr/cable-assemblies/coaxial-cables-rf/456?k=&pkeyword=&pv29=32&pv726=369&pv727=357&pv77=3182&FV=ffe001c8&quantity=0&ColumnSort=0&page=1&pageSize=25
krasny
March 28, 2018, 1:34pm
3
Or if you don’t mind to wait for chinese shipping:
https://es.aliexpress.com/item/1-pcs-for-PCI-Wifi-Card-U-FL-IPX-to-RP-SMA-female-RF-Pigtail-Cable/32615723458.html
Sorry, I though that you wanted to replace the filter as well, if you want to replace only the cable you can use this one:
link
I see, my message wasn’t clear, there is an antenna in the middle without filter. I don’t mind waiting some time, will use the second link and order couple of cables.
Many Thanks
