Access token not working with qrcode
I followed the following instructions to generate an access token :
So while scanning the qrcode I got the following error:
Download token error! Is device connected to the same network as Turris router
Well I am connected over WiFi on the Turris router. Do you have any idea of what should I checked ?
Nevermind, problem solved.
I’m using an SSH tunnel for the router web interface. So any devices can access the qrcode token.
