Actually, I did, but since it did not work, I searched for other manuals and found the mentioned page. BTW, the result was the same…
root:~# ip addr sh
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 532
link/ether d8:58:d7:00:37:eb brd ff:ff:ff:ff:ff:ff
inet6 fe80::da58:d7ff:fe00:37eb/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 532
link/ether d8:58:d7:00:37:e9 brd ff:ff:ff:ff:ff:ff
inet6 fe80::da58:d7ff:fe00:37e9/64 scope link
4: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 532
link/ether d8:58:d7:00:37:ea brd ff:ff:ff:ff:ff:ff
inet 10.67.65.10/24 brd 10.67.65.255 scope global eth2
inet6 fe80::da58:d7ff:fe00:37ea/64 scope link
5: lan0@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN group default qlen 1000
6: lan1@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN group default qlen 1000
7: lan2@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP group default qlen 1000
8: lan3@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN group default qlen 1000
9: lan4@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc noqueue state UP group default qlen 1000
inet 192.168.1.2/24 brd 192.168.1.255 scope global lan4
10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1000
link/tunnel6 :: brd ::
11: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
12: ifb0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether f6:de:4f:0c:9a:5e brd ff:ff:ff:ff:ff:ff
13: ifb1: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether 86:df:2d:d6:61:bd brd ff:ff:ff:ff:ff:ff
14: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1000
link/gre 0.0.0.0 brd 0.0.0.0
15: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
16: erspan0@NONE: <BROADCAST,MULTICAST> mtu 1450 qdisc noop state DOWN group default qlen 1000
19: br-guest_turris: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc htb state UP group default qlen 1000
link/ether 06:f0:21:22:da:4c brd ff:ff:ff:ff:ff:ff
inet 192.168.2.1/24 brd 192.168.2.255 scope global br-guest_turris
inet6 fe80::4f0:21ff:fe22:da4c/64 scope link
20: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.0.1/24 brd 192.168.0.255 scope global br-lan
29: wlan1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP group default qlen 1000
link/ether 04:f0:21:22:da:4c brd ff:ff:ff:ff:ff:ff
inet6 fe80::6f0:21ff:fe22:da4c/64 scope link
30: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP group default qlen 1000
link/ether 04:f0:21:24:09:ef brd ff:ff:ff:ff:ff:ff
inet6 fe80::6f0:21ff:fe24:9ef/64 scope link
36: guest_turris_1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-guest_turris state UP group default qlen 1000
38: ifb4br-guest_tu: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc htb state UNKNOWN group default qlen 32
link/ether 1e:5d:74:a1:1a:e9 brd ff:ff:ff:ff:ff:ff
inet6 fe80::1c5d:74ff:fea1:1ae9/64 scope link
49: 6in4-wan6@NONE: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1480 qdisc noqueue state UNKNOWN group default qlen 1000
link/sit 10.67.65.10 peer 216.66.86.122
inet6 fe80::a43:410a/64 scope link
50: tun_turris: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 100
link/none
inet 10.111.111.1 peer 10.111.111.2/32 scope global tun_turris
inet6 fe80::53c2:9c0f:8af6:a578/64 scope link stable-privacy
root:~# ip route
default via 10.67.65.1 dev eth2 proto static
10.67.65.0/24 dev eth2 proto kernel scope link src 10.67.65.10
10.111.111.0/24 via 10.111.111.2 dev tun_turris
10.111.111.2 dev tun_turris proto kernel scope link src 10.111.111.1
38.142.177.19 via 10.67.65.1 dev eth2 proto static
192.168.0.0/24 dev br-lan proto kernel scope link src 192.168.0.1
192.168.1.0/24 dev lan4 proto static scope link
192.168.2.0/24 dev br-guest_turris proto kernel scope link src 192.168.2.1
192.168.15.0/24 via 192.168.1.1 dev lan4 proto static
216.66.86.122 via 10.67.65.1 dev eth2 proto static
I’m surprised by the permission denied
error.
Thanks, ales
