I’ve had my Turris Omnia since the kickstarter campaign and I couldn’t be happier. It’s fast, snappy, and I’ve never had any major problems… Until now.
One day I noticed that only my 2.4 ghz wifi network is available. The 5ghz is simply gone. I’ve tried everything I can think of:
- Power cycle
- Turn that Wi-fi module on and off in LuCI
- Change settings related to WiFi
- Ensure that the connection to antenna is good
which admittedly is not much and I’m not sure where else to turn.
Let’s assume I barely know what I’m doing - what should I try? Where should I look? Is there any info I can post in here (and where do I find it) that can help you? Is it possible the card is dead? How can I get another one to repair it if so?
