I’ve got a Mox with the SDIO for 2.4 GHz and a wle1216v5-20 for 5.0 GHz. The WLE works fine. However, with the following configuration, although everything works fine at first, the MOX crashes within several minutes of startup (the light stops blinking on the front, no access to it possible):
radio0 corresponds to my WLE: “Qualcomm Atheros QCA9984 802.11acn”
radio1 corresponds to the SDIO “Generic MAC80211 802.11acbgn” (Is that even the right identifier? I googled and tried different drivers but I’m not getting anything more specific than the Generic one)
do not use any built-in wifi card and Mox will be rock-stable
I use Mox as classic router without wifi, I have connected Raspberry Pi 3+ via patchcord and Raspberry makes for me wifi ( project https://github.com/billz/raspap-webgui , raspi can do 2,4 or 5 GHz wifi )
combination of Mox without wifi with Turris Os 5.x and raspi as wifi is rock-stable
due to instable drivers for built-in wifi cards is not Mox usable with wifi, without wifi is very good and stable
Since it isn’t looking good using the SDIO chip, I ended up using my MOX B module to add a second wifi card (WLE900VX). Works great. It’s a shame the SDIO wifi component is garbage though.
