Dear Turris testers,
we will release Turris OS 3.8.3 into an RC branch in following minutes. It is already tested but we would like to test it more
You know, DNS and DHCP could be tricky, so please, try as much testing scenarios as possible. We are using dnsmasq only for DHCP by default but everything is possible with open system. Other changes could brings the smile to NAS box users and make openssh more secure again.
Changes are:
dnsmasq: various security fixes
kernel: various small fixes
openssh: security update
asm1062: workaround for error with SATA controller
The whole Turris team wishes you happy testing and we are looking forward to reading your feedback!
Sooner feedback means sooner release. And we want to keep you secure
There is a typo error in Czech version of release message in Foris. We are sorry for that, we had already corrected it but we did not want to postpone the release (building the release takes some time) just because of it
So I switched to RC branch on mine Turris 1.0 and I see there are four minor issues:
Output from openssh-server.postinst:
/var/etc/ssh/sshd_config line 5: Deprecated option UsePrivilegeSeparation
and the second one is really minor. There is just a typo:
The third is about tvheadend package, I tried also remove some other things, but I can see it only in this case:
root@turris:~# opkg install tvheadend
Installing tvheadend (4.2.3-0) to rootâŠ
Downloading https://repo.turris.cz/turris-rc/packages//turrispackages/tvheadend_4.2.3-0_mpc85xx.ipk
100 7048k 100 7048k 0 0 3595k 0 0:00:01 0:00:01 --:â:-- 3725k
Configuring tvheadend.
root@turris:~# opkg remove tvheadend
Removing package tvheadend from root⊠Command failed: Not found
root@turris:~# tvheadend
-ash: tvheadend: not found
So TVheadend itâs uninstalled, but why it says command failed?
and the last one (is still valid) and itâs only for Turris 1.x in Foris under tab âUpdaterâ it says that I have Turris Omnia instead of Turris (I also created issue #62 in Gitlab - Foris 3 months ago)
I see thereâs kernel update for us as well, but my question is about driver for MediaTek MT76x2 or RTL8812AU
Can it be included in next Turris version? I think I can compile it by myself, but if Iâm right then Iâd need to manually install it (or compile it, too) after each kernel update.
I was thinking that I can use atleast one of those USB WiFi dongles (Comfast CF-912AC or CF-926AC) as Access Points. Because chipset MT7612U looks very promising atleast for my case of usage.
Btw wasnt the typo error in English message instead of Czech?
Probably some minor issue in init script that it outputs some useless errors when stoping service that isnât started.
If somebody packaged it somewhere or you send a pull request with package, shouldnât be a big issue to include it in 3.9 (as long as it compiles and we wouldnât have fix bugs in it).
The latest I can find here: LEDE (then OpenWRT, but there it is almost 2 yrs old)
I also found packages pre-compiled it both repositories - in OpenWRT - kernel doesnât match and in LEDE (one that I have incompatible architecture and the second one more common: âcannot installâ)
I think better questions are:
Why it was mt76 removed from TurrisOS repo and why it isnât there?
Why we need to ask for something, which is supported in LEDE/OpenWRT? (I know that TurrisOS will be based on LEDE soon and hopefully we will have same or more modules/packages as LEDE than right now)
If I can use packages from one of those repositories I woudnât complain about it, but right now there are three solutions for me:
Spend time and compile it by myself (why I would do that, when somebody already spent his/her time to have it in OpenWRT/LEDE? )
Wait to have it in TurrisOS repository
Ask for support.
Hopefully things will improve in near future.
Back to issues:
And another issue is still there from 3.8.x for Turris 1.x.
We donât have locale support for Nextcloud as it is mention there:
and there is also yourâs reply when you said 21 days ago that you will look into it.
From git log: Remove as it doesnât build and we donât need it
Simple. Because that it was built once somewhere somehow doesnât mean that it will build everywhere all the time And we have limited resources, so we are not fixing every might be helpful to somebody package if it doesnât build.
You canât use those repositories, because the build system is a mess and federation is something light years ahead There is fourth option, compile it and send a pull request
Yep, I still plan to look into it deeper, but based on the preliminary findings it would need more radical change and thus a lot more testing and thus no go for fix-up releases.
Updated to RC 3.8.3 after some hesitation SFSG but I do have simple configuration only. Found discrepancy between documentation How to test Turris OS branches and releases and hint in forum How to test RC branches - different URL in /etc/opkg/distfeeds.conf. Anyhow, Omnia is up and running!
