3.8.2 in RC: DNS fixes and more
Dear Turris testers,
we will release Turris OS 3.8.2 into an RC branch in following minutes. It is already tested but we would like to test it more :wink: You know, DNS is kind of a big thing and we did not settle only with DNS fixes in this release.
Changes are:
  • knot-resolver: automaticly temporally turn off IPv6 if it doesn’t work
  • mac80211: few fixes from LEDE
  • nethist: fixed crash when too many interfaces are present on the router
  • dnsmasq and swconfig: fix broken dhcp and switch after Turris Omnia update from factory
  • nextcloud-install: better database handling
The whole Turris team wishes you happy testing and we are looking forward to reading your feedback!
Deploy for all should be on Monday.
I can not test, I do not have hardware and lxc can not be installed.
The same for me (I haven’t necessary redundant hardware for testing).
I’m waiting for deploy version on Monday (maybe) …
Will this fix the problems with the OpenVPN client/ firewall introduced in 3.8.0?
We just released 3.8.2 RC2.
There are:
  • new kernel for better security
  • new OpenVPN for better security
  • possible fix for Turris 1.x random reboots based on the only log we got from the tester. Worked for us too :slight_smile:
Probably not, we were not aware of this.
After update dont work WiFi And internet !
Turris 1.1
Log send on tech support
Thanks for the log, working on it :wink:
the new firmware version for the qca9888 (wle650v5-18) crashed:
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.925762] ath10k_pci 0000:03:00.0: firmware crashed! (uuid 718d9621-c757-4bad-8003-6846ab7272d6)
2017-10-02T23:48:02+02:00 info kernel[]: [ 781.934768] ath10k_pci 0000:03:00.0: qca9888 hw2.0 target 0x01000000 chip_id 0x00000000 sub 0000:0000
2017-10-02T23:48:02+02:00 info kernel[]: [ 781.934775] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
2017-10-02T23:48:02+02:00 info kernel[]: [ 781.938166] ath10k_pci 0000:03:00.0: firmware ver 10.4-ct-9888-fW-009-cf18e19 api 5 features peer-flow-ctrl crc32 35ea5db8
2017-10-02T23:48:02+02:00 info kernel[]: [ 781.938560] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id 0:17 crc32 74a04250
2017-10-02T23:48:02+02:00 info kernel[]: [ 781.938566] ath10k_pci 0000:03:00.0: htt-ver 2.2 wmi-op 6 htt-op 4 cal otp max-sta 32 raw 0 hwcrypto 1
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.940604] ath10k_pci 0000:03:00.0: firmware register dump:
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.946303] ath10k_pci 0000:03:00.0: [00]: 0x0000000C 0x00000000 0x009AF81C 0x00000555
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.954257] ath10k_pci 0000:03:00.0: [04]: 0x009AF81C 0x00060D30 0x00000000 0x0043C54C
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.962203] ath10k_pci 0000:03:00.0: [08]: 0x00000001 0x0045336C 0x00453350 0x00000024
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.970148] ath10k_pci 0000:03:00.0: [12]: 0x00000009 0x00000000 0x0097382C 0x00973842
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.978097] ath10k_pci 0000:03:00.0: [16]: 0x00973820 0x0096F2DC 0x009BFBED 0x00000000
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.986042] ath10k_pci 0000:03:00.0: [20]: 0x409AF81C 0x00405DCC 0x00000001 0x00000555
2017-10-02T23:48:02+02:00 err kernel[]: [ 781.993982] ath10k_pci 0000:03:00.0: [24]: 0x80982E21 0x00405E2C 0x00000001 0xC09AF81C
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.001924] ath10k_pci 0000:03:00.0: [28]: 0x80990908 0x00405E5C 0x0043511C 0x0044DE4C
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.009867] ath10k_pci 0000:03:00.0: [32]: 0x80990963 0x00405E8C 0x00427928 0x0044DE4C
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.017814] ath10k_pci 0000:03:00.0: [36]: 0x80990EC7 0x00405EBC 0x00000002 0x00438838
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.025761] ath10k_pci 0000:03:00.0: [40]: 0x80992D82 0x00405EEC 0x00427928 0x00438838
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.033700] ath10k_pci 0000:03:00.0: [44]: 0x8098EA90 0x00405F4C 0x00427928 0x00000000
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.041641] ath10k_pci 0000:03:00.0: [48]: 0x80963BFA 0x004060DC 0x00427928 0x0098EA88
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.049589] ath10k_pci 0000:03:00.0: [52]: 0x80960EC8 0x004060FC 0x0000001F 0x00400000
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.057528] ath10k_pci 0000:03:00.0: [56]: 0x80960E99 0x0040612C 0x00400000 0x00000000
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.065474] ath10k_pci 0000:03:00.0: Copy Engine register dump:
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.071412] ath10k_pci 0000:03:00.0: [00]: 0x0004a000 6 6 3 3
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.077883] ath10k_pci 0000:03:00.0: [01]: 0x0004a400 19 19 86 87
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.084346] ath10k_pci 0000:03:00.0: [02]: 0x0004a800 24 24 23 24
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.090812] ath10k_pci 0000:03:00.0: [03]: 0x0004ac00 1 1 3 1
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.097280] ath10k_pci 0000:03:00.0: [04]: 0x0004b000 4862 4862 185 145
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.103925] ath10k_pci 0000:03:00.0: [05]: 0x0004b400 28 28 27 28
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.110384] ath10k_pci 0000:03:00.0: [06]: 0x0004b800 24 24 24 24
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.116855] ath10k_pci 0000:03:00.0: [07]: 0x0004bc00 1 1 1 1
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.123319] ath10k_pci 0000:03:00.0: [08]: 0x0004c000 0 0 127 0
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.129784] ath10k_pci 0000:03:00.0: [09]: 0x0004c400 1 1 1 1
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.136249] ath10k_pci 0000:03:00.0: [10]: 0x0004c800 0 0 0 0
2017-10-02T23:48:02+02:00 err kernel[]: [ 782.142715] ath10k_pci 0000:03:00.0: [11]: 0x0004cc00 0 0 0 0
2017-10-02T23:48:02+02:00 info kernel[]: [ 782.223649] ieee80211 phy0: Hardware restart was requested
2017-10-02T23:48:06+02:00 info kernel[]: [ 786.010448] ath10k_pci 0000:03:00.0: device successfully recovered
There was no change in qca9888 firmware in 3.8.2 Did it happen just once or can you reliably reproduce it on your card?
Sorry it was my mistake. The change was in ath10k-firmware-qca988x.
I had installed the ath10k-firmware-qca9888-ct. This crashed periodically. Now I have the ath10-firmware-qca9888 installed, this works without problems. A question still: The firmware is only copied with a Power on/off new on the Wlan module and not with a restart?
best regards
Roland
The 3.8.2 had been released. Thanks for the testing!
This topic will be closed at 23:59 CET today.
Po update na v3.8.2. nefunguje moutovaní externích disku, nefunguje internet…
Rodinka v panice restartla router stylem zásuvka OFF/ON (což byla chyba, teď mají nefunkční 3.8.2 :slight_smile: a pak spustili poplach. Na dálku se mi zprostředkovaně podařilo zjistit následující -> vypadá to minimálně na problém iptables -> kernel verze/modul verze ??? více info až se večer dostanu k routeru. Na dálku s pomocí potomka vymazána MMC, reboot do verze 3.8.1 z NAND a zatím funkční, dnešek tedy snad po návratu domů přežiju a pošlu další info, pokud mě někdo nepředběhne :slight_smile:
Píši sem, protože do českého vlákna o uvolnění v3.8.2 se pro jistotu nedá nic postnout :slight_smile:
To stejné jsem jim psal hned po vydání RC2, logy již mají od včerejška, ale stejně to vydali :slight_smile:
Koukám se, no asi nějaký šotek při testování (pořád doufám, že situace, kdy jakýkoliv update rozbije router tak, že nefunguje ani přístup na internet, je jen dočasná a jednou se to zlomí :-)) Pravdou je, že pověst routeru coby spolehlivé síťové komponenty o které se léta neví, poněkud úhlem pohledu na Turris poslední dobou trpí :wink:
Ano mohu potvrdit. Po aktualizaci na 3.8.2 mého Turrise 1.0 jsem si akorát všimla po restartu na seriové konzoli něco jako “no kernel image found” a nic nefungovalo, wifi, ethernet, disky etc.
Tak mě to už naštvalo a rovnou si udělala migraci na UBIFS a bootovat z MicroSD kvuli btrfs a schnappsu. To se kupodivu vše provedlo. Akorát během provozu se zase odpojily disky (síť fungovala), po restartu to zase na 3.8.2. chvilku jede… ale je tam něco špatně.
Já se po lan kabelu dostanu normálně ke správě routeru, naštěstí to nemusím řešit seriovou linkou. Jen ty disky mě nenapadlo zkontrolovat. Každopádně taky mě zachránilo btrfs, bez něj bych mel mrtvou kostku.
This topic was automatically closed after 12 hours. New replies are no longer allowed.
