3.10.3 - SQM cake not working
luci-app-sqm |1.0.7-3|
sqm-scripts |1.0.7-3|
sqm-scripts-extra |2016-06-08-1|
from the SQM log
Starting SQM script: piece_of_cake.qos on pppoe-wan, in: 92000 Kbps, out: 19500 Kbps
/usr/sbin/ip link add name TMP_IFB_4_SQM type ifb
/usr/sbin/tc qdisc replace dev TMP_IFB_4_SQM root cake
RTNETLINK answers: No such file or directory
/usr/sbin/ip link set dev TMP_IFB_4_SQM down
/usr/sbin/ip link delete TMP_IFB_4_SQM type ifb
manually from cli
ip l ls TMP_IFB_4_SQM
48: TMP_IFB_4_SQM: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 32
link/ether 8e:02:a1:e2:48:d0 brd ff:ff:ff:ff:ff:ff
Works for me in my configuration (two different Omnias), changes made just yesterday. Configuration snippets would be useful: it’s hard to tell what’s going on here.
/etc/sqm/sqm.conf
SQM_LIB_DIR=/usr/lib/sqm
SQM_STATE_DIR=/var/run/sqm
SQM_QDISC_STATE_DIR=${SQM_STATE_DIR}/available_qdiscs
SQM_CHECK_QDISCS="fq_codel efq_codel nfq_codel sfq codel ns2_codel pie sfq cake"
SQM_SYSLOG=1
/etc/config/sqm
config queue
	option verbosity '5'
	option qdisc 'fq_codel'
	option enabled '1'
	option download '92000'
	option upload '19000'
	option debug_logging '1'
	option qdisc_advanced '0'
	option script 'piece_of_cake.qos'
	option linklayer 'ethernet'
	option overhead '8'
	option interface 'pppoe-wan'
The main difference is that I use cake in qdisc and I have all sorts of advanced features activated (but those are specific to my connection)
Tried now simple.qos and simplest.qos and both are working.
piece_of_cake.qos and layer_cake.qos are neither working
what is the output of:
tc -s qdisc
Summary
qdisc noqueue 0: dev lo root refcnt 2
Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
backlog 0b 0p requeues 0
qdisc mq 0: dev eth0 root
Sent 4226334726 bytes 5334054 pkt (dropped 0, overlimits 0 requeues 852)
backlog 0b 0p requeues 852
qdisc fq_codel 0: dev eth0 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
maxpacket 21196 drop_overlimit 0 new_flow_count 21713 ecn_mark 0
new_flows_len 0 old_flows_len 0
qdisc fq_codel 0: dev eth0 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
maxpacket 0 drop_overlimit 0 new_flow_count 0 ecn_mark 0
qdisc fq_codel 0: dev eth0 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :5 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :6 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :7 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth0 parent :8 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc mq 0: dev eth1 root
Sent 739928333 bytes 2971492 pkt (dropped 0, overlimits 0 requeues 711)
backlog 0b 0p requeues 711
qdisc fq_codel 0: dev eth1 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
maxpacket 1514 drop_overlimit 0 new_flow_count 324 ecn_mark 0
qdisc fq_codel 0: dev eth1 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :5 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :6 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :7 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth1 parent :8 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc mq 0: dev eth2 root
Sent 2874703 bytes 15935 pkt (dropped 0, overlimits 0 requeues 0)
qdisc fq_codel 0: dev eth2 parent :1 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
maxpacket 221 drop_overlimit 0 new_flow_count 1 ecn_mark 0
qdisc fq_codel 0: dev eth2 parent :2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :3 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :4 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :5 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :6 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :7 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc fq_codel 0: dev eth2 parent :8 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
qdisc noqueue 0: dev br-guest root refcnt 2
qdisc noqueue 0: dev br-lan root refcnt 2
qdisc noqueue 0: dev wlan1 root refcnt 2
qdisc noqueue 0: dev wlan0 root refcnt 2
qdisc noqueue 0: dev guest0 root refcnt 2
qdisc fq_codel 0: dev pppoe-wan root refcnt 2 limit 1024p flows 1024 quantum 1514 target 5.0ms interval 100.0ms ecn
Sent 74754 bytes 689 pkt (dropped 0, overlimits 0 requeues 0)
maxpacket 52 drop_overlimit 0 new_flow_count 1 ecn_mark 0
new_flows_len 1 old_flows_len 0
qdisc noqueue 0: dev wg0 root refcnt 2
cake does not appear in the LuCI → SQM → Queuing disciplines, only fq_codel, pie, codel and sfq?
That is an indicator that the kernel module somehow was not installed* (which also matches your observed behaviour, but what does
/etc/init.d/sqm stop ; /etc/init.d/sqm start ; logread | grep -e “SQM”
output? Maybe you could try to install cake again?
Best Regards
*) sqm tests whether the qdiscs in SQM_CHECK_QDISCS are actually usable, if they are missing or simply not working they are not listed in the GUI.
removed/reinstalled kmod-sched-cake and seems working now. Thanks for the pointer
