2.5Gbps mode not working with ODI DFP-34X-2C2 SFP module
Hi there!
After watching this “Van Tech Corner Replace ISP ONU with PON Stick” video on youtube, I managed this module to work (ISP MZNet Fibra from Brazil, VLAN ID 2000) in my Turris Omnia running TOS 6.0.4:
Perhaps, the 2.5Gb mode is not recognized. I can set it on the ODI telnet cmdline (as reported in this repo), but it is downgrading to 1Gb mode, as below:
ODI boot log:
 net_device_ops yet
<6>eth0: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
<6>eth0.2 (): not using net_device_ops yet
<6>eth0.2: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
<6>eth0.3 (): not using net_device_ops yet
<6>eth0.3: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
<6>nas0 (): not using net_device_ops yet
<6>nas0: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
<4>>>>> Set nas0 carrier off !!!
<6>pon0 (): not using net_device_ops yet
<6>pon0: RTL-8686 at 0xb8012000, 00:00:00:01:00:02, IRQ 26
<4>RTL8686 GMAC Probing..
<4>first entry: 0, portmask 127, rx: 802334ec
<4>nas0 -> 0x4
<4>Init RTK Driver Module....*** [RT_DBG] drivers/net/rtl86900/sdk/src//dal/rtl9602c/dal_rtl9602c_classify.c:3567: In function 'dal_rtl9602c_classify_unmatchAction_set' action 2
<4>
<4>OK
<4>Init RTK Core Dev Module....OK
<4>
<4> rtdrv_init !!! for netfilter
<4>pkt_redirect_init complete
<5>interrupt broadcaster init ok!
<4>u32 classifier
<4>nf_conntrack version 0.5.0 (479 buckets, 1916 max)
<6>ip_tables: (C) 2000-2006 Netfilter Core Team
<6>TCP cubic registered
<6>NET: Registered protocol family 17
<5>Bridge firewalling registered
<6>Ebtables v2.0 registered
<6>802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
<6>All bugs added by David S. Miller <davem@redhat.com>
<4>Realtek GPIO Driver for Flash Reload Default
<5>physmap platform flash device: 0b000000 at 14000000
<4>Luna SPI NOR FLASH G3 driver-C22017/MMIO16-1 <5>master->name physmap-flash
<5>cmd: cmdlinepart
<5>14 cmdlinepart partitions found on MTD device physmap-flash
<5>Creating 14 MTD partitions on "physmap-flash":
<5>0x000000000000-0x000000040000 : "boot"
<5>0x000000040000-0x000000042000 : "env"
<5>0x000000042000-0x000000044000 : "env2"
<5>0x000000044000-0x000000080000 : "config"
<5>0x000000080000-0x0000001cc000 : "k0"
<5>0x0000001cc000-0x000000440000 : "r0"
<5>0x000000440000-0x00000058c000 : "k1"
<5>0x00000058c000-0x000000800000 : "r1"
<5>0x000000000000-0x000000001000 : "Partition_008"
<5>0x000000000000-0x000000001000 : "Partition_009"
<5>0x000000000000-0x000000001000 : "Partition_010"
<5>0x000000000000-0x000000001000 : "Partition_011"
<5>0x000000080000-0x0000001cc000 : "linux"
<5>0x0000001cc000-0x000000440000 : "rootfs"
<4>VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
<6>Freeing unused kernel memory: 100k freed
<4>re8670_open 3341
<4>omci platform attached!
<4>*** [RT_ERR] drivers/net/rtl86900/sdk/src//dal/rtl9602c/dal_rtl9602c_ponmac.c:1039: In function '_rtl9602c_ponMacGponModeV2_set'
<4>             Error Code: 0x8848
<4>
<4>*** [RT_DBG] drivers/net/rtl86900/sdk/src//dal/rtl9602c/dal_rtl9602c_classify.c:3567: In function 'dal_rtl9602c_classify_unmatchAction_set' action 1
<4>
<4>
<3>register_gpon_evt_state: register gpon event state Successfully !
<4>priority: 0, portmask 127, rx: 802334ec
<4>insert here, priority: 7, portmask 255, rx: c026b34c
<4>change mode to 4(HiSGMII PHY)
<4>send to user app (5) fail (-1)
<4>write watchdog_flag to 0x00000001
<4>[Kthread : watchdog ] init complete!
<4>************ Watchdog Setting ****************
<4>WDT_E=1, (1-enable, 0-disable)
<4>LX(MHz)=200
<4>WDT_CLK_SC=3
<4>PH1_TO=31
<4>PH2_TO=0
<4>WDT_RESET_MODE=0
<4>**********************************************
<4>port 2 assign to pon0
<4>pon0 -> 0x4
<6>device eth0 entered promiscuous mode
<4>priority: 7, portmask 255, rx: c026b34c
<4>insert here, priority: 4, portmask 4, rx: 80172968
<6>br0: port 1(eth0) entering learning state
<4>drivers/net/rtl86900/sdk/src/rtk/pon_led.c:1152 led sw blink init complete!
<6>br0: port 1(eth0) entering forwarding state
<4>drivers/net/rtl86900/sdk/src/module/lan_sds/lan_sds_main.c:679 SFP_TASK_MASK_EEPROM_128TO247
<4>change mode to 1(Fiber 1G)
<4>eth0: received packet with  own address as source address 38-3a-21-27-eb-86 loop intf=0 0
Turris boot log:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.15.82 (packaging@turris.cz) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 8.4.0 r16803+125-784565b6a0) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Sun Dec 11 23:19:41 2022
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Turris Omnia
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] percpu: Embedded 11 pages/cpu s14732 r8192 d22132 u45056
[    0.000000] pcpu-alloc: s14732 r8192 d22132 u45056 alloc=11*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522560
[    0.000000] Kernel command line: earlyprintk rootwait  console=ttyS0,115200 rootfstype=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rw cfg80211.freg=**
[    0.000000] Bootloader command line not present
[    0.000000] Unknown kernel command line parameters "earlyprintk mangled_fs=btrfs", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 2063496K/2097152K available (9216K kernel code, 669K rwdata, 2180K rodata, 1024K init, 258K bss, 33656K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] Registering MPIC SoC Error Interrupt Controller
[    0.000000] L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 D prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[    0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[    0.000001] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
[    0.000018] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
[    0.000036] Switching to timer-based delay loop, resolution 1ns
[    0.000180] Ignoring duplicate/late registration of read_current_timer delay
[    0.000187] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000374] Console: colour dummy device 80x30
[    0.000404] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
[    0.000414] pid_max: default: 32768 minimum: 301
[    0.000509] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000519] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000917] CPU: Testing write buffer coherency: ok
[    0.000939] CPU0: Spectre v2: using BPIALL workaround
[    0.001041] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001341] Setting up static identity map for 0x100000 - 0x100060
[    0.001423] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[    0.001511] mvebu-pmsu: Initializing Power Management Service Unit
[    0.001571] rcu: Hierarchical SRCU implementation.
[    0.001646] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.001708] smp: Bringing up secondary CPUs ...
[    0.001872] Booting CPU 1
[    0.002015] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.002022] CPU1: Spectre v2: using BPIALL workaround
[    0.002081] smp: Brought up 1 node, 2 CPUs
[    0.002088] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[    0.002093] CPU: All CPU(s) started in SVC mode.
[    0.002453] devtmpfs: initialized
[    0.004314] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.004366] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.004376] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.004451] pinctrl core: initialized pinctrl subsystem
[    0.005001] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.005604] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.006058] thermal_sys: Registered thermal governor 'step_wise'
[    0.006200] cpuidle: using governor ladder
[    0.006290] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.006297] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.006421] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[    0.006429] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[    0.014955] cryptd: max_cpu_qlen set to 1000
[    0.015753] raid6: skip pq benchmark and using algorithm neonx8
[    0.015761] raid6: using neon recovery algorithm
[    0.016028] SCSI subsystem initialized
[    0.016108] libata version 3.00 loaded.
[    0.016197] usbcore: registered new interface driver usbfs
[    0.016218] usbcore: registered new interface driver hub
[    0.016236] usbcore: registered new device driver usb
[    0.016860] clocksource: Switched to clocksource arm_global_timer
[    0.019111] NET: Registered PF_INET protocol family
[    0.019224] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.019763] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.019783] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.019793] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.019833] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.019897] TCP: Hash tables configured (established 8192 bind 8192)
[    0.019946] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.019977] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.020118] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.020138] PCI: CLS 0 bytes, default 64
[    0.020610] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.022525] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.024510] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.024517] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.024966] xor: measuring software checksum speed
[    0.028802]    arm4regs        :  2598 MB/sec
[    0.033729]    8regs           :  1998 MB/sec
[    0.038288]    32regs          :  2160 MB/sec
[    0.043502]    neon            :  1887 MB/sec
[    0.043506] xor: using function: arm4regs (2598 MB/sec)
[    0.043548] bounce: pool size: 64 pages
[    0.043578] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.044713] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[    0.045254] debugfs: Directory 'f1018100.gpio' with parent 'regmap' already present!
[    0.045567] debugfs: Directory 'f1018140.gpio' with parent 'regmap' already present!
[    0.045892] mvebu-pcie soc:pcie: host bridge /soc/pcie ranges:
[    0.045920] mvebu-pcie soc:pcie:      MEM 0x00f1080000..0x00f1081fff -> 0x0000080000
[    0.045935] mvebu-pcie soc:pcie:      MEM 0x00f1040000..0x00f1041fff -> 0x0000040000
[    0.045949] mvebu-pcie soc:pcie:      MEM 0x00f1044000..0x00f1045fff -> 0x0000044000
[    0.045963] mvebu-pcie soc:pcie:      MEM 0x00f1048000..0x00f1049fff -> 0x0000048000
[    0.045987] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
[    0.046000] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
[    0.046012] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
[    0.046024] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
[    0.046036] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
[    0.046048] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
[    0.046060] mvebu-pcie soc:pcie:      MEM 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
[    0.046069] mvebu-pcie soc:pcie:       IO 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
[    0.046167] mvebu-pcie soc:pcie: pcie0.0: Slot power limit 10.0W
[    0.046223] mvebu-pcie soc:pcie: pcie1.0: Slot power limit 10.0W
[    0.046274] mvebu-pcie soc:pcie: pcie2.0: Slot power limit 10.0W
[    0.046823] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[    0.046835] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.046845] pci_bus 0000:00: root bus resource [mem 0xf1080000-0xf1081fff] (bus address [0x00080000-0x00081fff])
[    0.046880] pci_bus 0000:00: root bus resource [mem 0xf1040000-0xf1041fff] (bus address [0x00040000-0x00041fff])
[    0.046894] pci_bus 0000:00: root bus resource [mem 0xf1044000-0xf1045fff] (bus address [0x00044000-0x00045fff])
[    0.046902] pci_bus 0000:00: root bus resource [mem 0xf1048000-0xf1049fff] (bus address [0x00048000-0x00049fff])
[    0.046908] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[    0.046913] pci_bus 0000:00: root bus resource [io  0x1000-0xeffff]
[    0.046988] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
[    0.047167] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[    0.047309] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[    0.048158] PCI: bus0: Fast back to back transfers disabled
[    0.048166] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.048177] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.048186] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.049032] PCI: bus1: Fast back to back transfers enabled
[    0.049039] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.049113] pci 0000:02:00.0: [14c3:7915] type 00 class 0x000280
[    0.049135] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[    0.049150] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00003fff 64bit pref]
[    0.049163] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00000fff 64bit pref]
[    0.049235] pci 0000:02:00.0: supports D1 D2
[    0.049241] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.050137] PCI: bus2: Fast back to back transfers disabled
[    0.050145] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    0.050218] pci 0000:03:00.0: [168c:003c] type 00 class 0x028000
[    0.050240] pci 0000:03:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[    0.050267] pci 0000:03:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    0.050338] pci 0000:03:00.0: supports D1 D2
[    0.051233] PCI: bus3: Fast back to back transfers disabled
[    0.051240] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[    0.051264] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe03fffff]
[    0.051273] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0400000-0xe07fffff]
[    0.051281] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0800000-0xe0bfffff]
[    0.051288] pci 0000:00:01.0: BAR 7: assigned [io  0x10000-0x10fff]
[    0.051295] pci 0000:00:02.0: BAR 7: assigned [io  0x20000-0x20fff]
[    0.051301] pci 0000:00:03.0: BAR 7: assigned [io  0x30000-0x30fff]
[    0.051307] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.051313] pci 0000:00:01.0:   bridge window [io  0x10000-0x10fff]
[    0.051325] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xe03fffff]
[    0.051338] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0400000-0xe04fffff 64bit pref]
[    0.051351] pci 0000:02:00.0: BAR 2: assigned [mem 0xe0500000-0xe0503fff 64bit pref]
[    0.051363] pci 0000:02:00.0: BAR 4: assigned [mem 0xe0504000-0xe0504fff 64bit pref]
[    0.051374] pci 0000:00:02.0: PCI bridge to [bus 02]
[    0.051380] pci 0000:00:02.0:   bridge window [io  0x20000-0x20fff]
[    0.051389] pci 0000:00:02.0:   bridge window [mem 0xe0400000-0xe07fffff]
[    0.051401] pci 0000:03:00.0: BAR 0: assigned [mem 0xe0800000-0xe09fffff 64bit]
[    0.051412] pci 0000:03:00.0: BAR 6: assigned [mem 0xe0a00000-0xe0a0ffff pref]
[    0.051419] pci 0000:00:03.0: PCI bridge to [bus 03]
[    0.051424] pci 0000:00:03.0:   bridge window [io  0x30000-0x30fff]
[    0.051433] pci 0000:00:03.0:   bridge window [mem 0xe0800000-0xe0bfffff]
[    0.051499] pcieport 0000:00:01.0: enabling device (0140 -> 0143)
[    0.051569] pcieport 0000:00:01.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    0.051818] pcieport 0000:00:01.0: pciehp: Slot(1): Card present
[    0.051875] pcieport 0000:00:02.0: enabling device (0140 -> 0143)
[    0.051937] pcieport 0000:00:02.0: pciehp: Slot #2 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    0.052349] pcieport 0000:00:03.0: enabling device (0140 -> 0143)
[    0.052406] pcieport 0000:00:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    0.052978] mv_xor f1060800.xor: Marvell shared XOR driver
[    0.066859] mvebu-pcie soc:pcie: pcie2.0: link up
[    0.066881] mvebu-pcie soc:pcie: pcie1.0: link up
[    0.107286] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    0.107425] mv_xor f1060900.xor: Marvell shared XOR driver
[    0.167255] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    0.167535] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.168854] printk: console [ttyS0] disabled
[    0.188949] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 30, base_baud = 15625000) is a 16550A
[    1.472877] printk: console [ttyS0] enabled
[    1.497557] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 31, base_baud = 15625000) is a 16550A
[    1.508949] loop: module loaded
[    1.512110] Loading iSCSI transport class v2.0-870.
[    1.518135] ahci-mvebu f10a8000.sata: supply ahci not found, using dummy regulator
[    1.525803] ahci-mvebu f10a8000.sata: supply phy not found, using dummy regulator
[    1.533349] ahci-mvebu f10a8000.sata: supply target not found, using dummy regulator
[    1.541192] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    1.550276] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[    1.559610] scsi host0: ahci-mvebu
[    1.563306] scsi host1: ahci-mvebu
[    1.566793] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 53
[    1.574749] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 53
[    1.583720] spi-nor spi0.0: found mx25l6405d, expected s25fl164k
[    1.589777] spi-nor spi0.0: mx25l6405d (8192 Kbytes)
[    1.594874] 2 fixed-partitions partitions found on MTD device spi0.0
[    1.601268] Creating 2 MTD partitions on "spi0.0":
[    1.606073] 0x000000000000-0x000000100000 : "U-Boot"
[    1.611345] 0x000000100000-0x000000800000 : "Rescue system"
[    1.618942] hwmon hwmon0: temp1_input not attached to any thermal zone
[    1.625948] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
[    1.635007] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:01:09:30
[    1.644333] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:01:09:2e
[    1.653631] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:01:09:2f
[    1.661811] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.668371] ehci-pci: EHCI PCI platform driver
[    1.672857] ehci-platform: EHCI generic platform driver
[    1.678186] ehci-orion: EHCI orion driver
[    1.682298] orion-ehci f1058000.usb: EHCI Host Controller
[    1.687728] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    1.695363] orion-ehci f1058000.usb: irq 49, io mem 0xf1058000
[    1.726864] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    1.733105] hub 1-0:1.0: USB hub found
[    1.736904] hub 1-0:1.0: 1 port detected
[    1.741260] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    1.746598] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    1.754174] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    1.763451] xhci-hcd f10f0000.usb3: irq 55, io mem 0xf10f0000
[    1.769297] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    1.774627] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    1.782174] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[    1.788815] hub 2-0:1.0: USB hub found
[    1.792590] hub 2-0:1.0: 1 port detected
[    1.796659] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.804996] hub 3-0:1.0: USB hub found
[    1.808780] hub 3-0:1.0: 1 port detected
[    1.812907] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    1.818255] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    1.825831] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    1.835106] xhci-hcd f10f8000.usb3: irq 56, io mem 0xf10f8000
[    1.840937] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    1.846266] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    1.853784] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[    1.860397] hub 4-0:1.0: USB hub found
[    1.864169] hub 4-0:1.0: 1 port detected
[    1.868240] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.876550] hub 5-0:1.0: USB hub found
[    1.880330] hub 5-0:1.0: 1 port detected
[    1.884485] usbcore: registered new interface driver usb-storage
[    1.891023] armada38x-rtc f10a3800.rtc: registered as rtc0
[    1.896593] armada38x-rtc f10a3800.rtc: setting system clock to 2022-12-12T03:00:48 UTC (1670814048)
[    1.905914] i2c_dev: i2c /dev entries driver
[    1.912471] orion_wdt: Initial timeout 171 sec
[    1.913058] ata2: SATA link down (SStatus 0 SControl 300)
[    1.917183] sdhci: Secure Digital Host Controller Interface driver
[    1.928562] sdhci: Copyright(c) Pierre Ossman
[    1.933038] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.939686] marvell-cesa f1090000.crypto: CESA device successfully registered
[    1.947366] NET: Registered PF_INET6 protocol family
[    1.952968] Segment Routing with IPv6
[    1.956661] In-situ OAM (IOAM) with IPv6
[    1.960659] NET: Registered PF_PACKET protocol family
[    1.965010] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[    1.965758] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.986243] 8021q: 802.1Q VLAN Support v1.8
[    1.990556] Registering SWP/SWPB emulation handler
[    1.997608] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    2.101993] mmc0: new high speed MMC card at address 0001
[    2.107763] mmcblk0: mmc0:0001 008G30 7.28 GiB
[    2.113634]  mmcblk0: p1
[    2.116471] mmcblk0boot0: mmc0:0001 008G30 4.00 MiB
[    2.121893] mmcblk0boot1: mmc0:0001 008G30 4.00 MiB
[    2.127146] mmcblk0rpmb: mmc0:0001 008G30 4.00 MiB, chardev (247:0)
[    2.966863] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.973130] ata1.00: ATA-9: GTA 256GB SSD, HCS1A25C, max UDMA/133
[    2.979250] ata1.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 32)
[    2.986773] ata1.00: configured for UDMA/133
[    2.991244] scsi 0:0:0:0: Direct-Access     ATA      GTA 256GB SSD    A25C PQ: 0 ANSI: 5
[    2.999803] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[    3.007350] sd 0:0:0:0: [sda] Write Protect is off
[    3.012155] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.012190] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.022240] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    3.029345] squashfs: Unknown parameter 'commit'
[    3.035028] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    3.042285] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[    3.050968] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    3.058220] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[    3.066898] BTRFS: device fsid ec715b08-b0a6-4fb2-aca1-07df948ffd7a devid 1 transid 2787793 /dev/root scanned by swapper/0 (1)
[    3.079709] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    3.086432] BTRFS info (device mmcblk0p1): has skinny extents
[    3.112892] BTRFS info (device mmcblk0p1): enabling ssd optimizations
[    3.126232] VFS: Mounted root (btrfs filesystem) on device 0:14.
[    3.133909] devtmpfs: mounted
[    3.137325] Freeing unused kernel image (initmem) memory: 1024K
[    3.177017] Run /sbin/init as init process
[    3.181124]   with arguments:
[    3.181126]     /sbin/init
[    3.181128]     earlyprintk
[    3.181130]   with environment:
[    3.181132]     HOME=/
[    3.181134]     TERM=linux
[    3.181136]     mangled_fs=btrfs
[    3.219493] init: Console is alive
[    3.222994] init: - watchdog -
[    3.296885] pcieport 0000:00:01.0: pciehp: Slot(1): No link
[    3.519262] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    3.534425] Key type encrypted registered
[    3.541185] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    3.552150] ehci-fsl: Freescale EHCI Host controller driver
[    3.559258] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.565862] ohci-platform: OHCI generic platform driver
[    3.575434] uhci_hcd: USB Universal Host Controller Interface driver
[    3.582303] ohci-pci: OHCI PCI platform driver
[    3.588666] usbcore: registered new interface driver uas
[    3.594123] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    3.604194] init: - preinit -
[    5.713755] mount_root: mounting /dev/root
[    5.720128] mount_root: loading kmods from internal overlay
[    5.738236] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[    5.746152] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[    6.414082] block: attempting to load /etc/config/fstab
[    6.421879] block: extroot: not configured
[    6.445681] urandom-seed: Seeding with /etc/urandom.seed
[    6.808721] BTRFS: device label srv devid 1 transid 50797 /dev/sda scanned by btrfs (625)
[    6.817026] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by btrfs (625)
[    6.828992] procd: - early -
[    6.831911] procd: - watchdog -
[    7.361619] procd: - watchdog -
[    7.364984] procd: - ubus -
[    7.374276] random: ubusd: uninitialized urandom read (4 bytes read)
[    7.417240] random: ubusd: uninitialized urandom read (4 bytes read)
[    7.423738] random: ubusd: uninitialized urandom read (4 bytes read)
[    7.430898] procd: - init -
[    7.795316] kmodloader: loading kernel modules from /etc/modules.d/*
[    7.862901] Key type dns_resolver registered
[    7.872624] RPC: Registered named UNIX socket transport module.
[    7.878600] RPC: Registered udp transport module.
[    7.883318] RPC: Registered tcp transport module.
[    7.888036] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    7.901273] tun: Universal TUN/TAP device driver, 1.6
[    7.912572] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    7.926561] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    8.079971] random: crng init done
[    8.083395] random: 23 urandom warning(s) missed due to ratelimiting
[    8.997155] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[    9.007059] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[    9.016454] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[    9.025365] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[    9.129145] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-0:00] driver [Marvell 88E1540] (irq=79)
[    9.240740] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-0:01] driver [Marvell 88E1540] (irq=80)
[    9.357204] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-0:02] driver [Marvell 88E1540] (irq=81)
[    9.476993] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-0:03] driver [Marvell 88E1540] (irq=82)
[    9.592029] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-0:04] driver [Marvell 88E1540] (irq=83)
[    9.608181] DSA: tree 0 setup
[    9.623331] NFS: Registering the id_resolver key type
[    9.628475] Key type id_resolver registered
[    9.632676] Key type id_legacy registered
[    9.686422] i2c i2c-0: Added multiplexed i2c bus 1
[    9.691420] i2c i2c-0: Added multiplexed i2c bus 2
[    9.696383] i2c i2c-0: Added multiplexed i2c bus 3
[    9.701518] i2c i2c-0: Added multiplexed i2c bus 4
[    9.706626] i2c i2c-0: Added multiplexed i2c bus 5
[    9.715721] i2c i2c-0: Added multiplexed i2c bus 6
[    9.720808] i2c i2c-0: Added multiplexed i2c bus 7
[    9.726282] pca953x 8-0071: supply vcc not found, using dummy regulator
[    9.733125] pca953x 8-0071: using no AI
[    9.740823] i2c i2c-0: Added multiplexed i2c bus 8
[    9.745658] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[    9.754270] sfp sfp: Host maximum power 3.0W
[    9.754886] GACT probability on
[    9.762343] Mirror/redirect action on
[    9.769931] u32 classifier
[    9.772662]     input device check on
[    9.776341]     Actions configured
[    9.785039] fuse: init (API version 7.34)
[    9.793212] at24 1-0054: supply vcc not found, using dummy regulator
[    9.804318] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[    9.811902] Bridge firewalling registered
[    9.821868] Loading modules backported from Linux version v5.15.58-0-g7d8048d4e064
[    9.829497] Backport generated by backports.git v5.15.58-1-0-g42a95ce7
[    9.855383] usbcore: registered new interface driver ums-alauda
[    9.861840] usbcore: registered new interface driver ums-cypress
[    9.868565] usbcore: registered new interface driver ums-datafab
[    9.875109] usbcore: registered new interface driver ums-freecom
[    9.881705] usbcore: registered new interface driver ums-isd200
[    9.892342] usbcore: registered new interface driver ums-jumpshot
[    9.899177] usbcore: registered new interface driver ums-karma
[    9.905774] usbcore: registered new interface driver ums-sddr09
[    9.912374] usbcore: registered new interface driver ums-sddr55
[    9.919025] usbcore: registered new interface driver ums-usbat
[    9.926107] usbcore: registered new interface driver usbserial_generic
[    9.932719] usbserial: USB Serial support registered for generic
[    9.954187] xt_time: kernel timezone is -0000
[    9.989459] mt7915e 0000:02:00.0: enabling device (0140 -> 0142)
[   10.098172] sfp sfp: module ODI              DFP-34X-2C2      rev      sn XPON22100614     dc 221009
[   10.107541] mvneta f1034000.ethernet eth2: switched to inband/1000base-x link mode
[   10.132855] mt7915e 0000:02:00.0: HW/SW Version: 0x8a108a10, Build Time: 20211222184017a
[   10.132855]
[   10.168508] mt7915e 0000:02:00.0: WM Firmware Version: ____000000, Build Time: 20211222184052
[   10.196071] mt7915e 0000:02:00.0: WA Firmware Version: DEV_000000, Build Time: 20211222184111
[   10.354933] PPP generic driver version 2.4.2
[   10.360192] NET: Registered PF_PPPOX protocol family
[   10.367669] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[   10.375530] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[   10.399272] ath10k_pci 0000:03:00.0: enabling device (0140 -> 0142)
[   10.405758] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   10.660499] ath10k_pci 0000:03:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   10.669776] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   10.679409] ath10k_pci 0000:03:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[   10.736708] ath10k_pci 0000:03:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   11.876556] ath10k_pci 0000:03:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   11.998290] ath: EEPROM regdomain: 0x0
[   11.998299] ath: EEPROM indicates default country code should be used
[   11.998301] ath: doing EEPROM country->regdmn map search
[   11.998305] ath: country maps to regdmn code: 0x3a
[   11.998308] ath: Country alpha2 being used: US
[   11.998311] ath: Regpair used: 0x3a
[   15.657664] usbcore: registered new interface driver qcserial
[   15.663462] usbserial: USB Serial support registered for Qualcomm USB modem
[   15.676783] kmodloader: done loading kernel modules from /etc/modules.d/*
[   18.465949] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[   18.474095] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[   18.482206] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   18.489378] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
[   18.502497] br-lan: port 1(lan0) entered blocking state
[   18.507784] br-lan: port 1(lan0) entered disabled state
[   18.564099] device lan0 entered promiscuous mode
[   18.568772] device eth1 entered promiscuous mode
[   18.741017] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
[   18.796955] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[   18.865008] br-lan: port 2(lan1) entered blocking state
[   18.865927] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[   18.870263] br-lan: port 2(lan1) entered disabled state
[   18.932264] device lan1 entered promiscuous mode
[   19.150136] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
[   19.190118] br-lan: port 1(lan0) entered blocking state
[   19.195376] br-lan: port 1(lan0) entered forwarding state
[   19.217202] br-lan: port 2(lan1) entered blocking state
[   19.222458] br-lan: port 2(lan1) entered forwarding state
[   19.241487] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   19.266844] BTRFS info (device sda): disk space caching is enabled
[   19.273071] BTRFS info (device sda): has skinny extents
[   19.303442] BTRFS info (device sda): enabling ssd optimizations
[   19.371538] br-lan: port 3(lan2) entered blocking state
[   19.376790] br-lan: port 3(lan2) entered disabled state
[   19.402155] mv88e6085 f1072004.mdio-mii:10 lan2: Link is Up - 1Gbps/Full - flow control rx/tx
[   19.983748] device lan2 entered promiscuous mode
[   20.012570] br-lan: port 3(lan2) entered blocking state
[   20.017843] br-lan: port 3(lan2) entered forwarding state
[   20.026829] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[   20.098417] br-lan: port 4(lan3) entered blocking state
[   20.103680] br-lan: port 4(lan3) entered disabled state
[   20.170789] device lan3 entered promiscuous mode
[   20.202401] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
[   20.277152] br-lan: port 5(lan4) entered blocking state
[   20.282411] br-lan: port 5(lan4) entered disabled state
[   20.344113] device lan4 entered promiscuous mode
[   20.383151] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
[   20.446951] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control rx/tx
[   20.455012] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[   20.461525] IPv6: ADDRCONF(NETDEV_CHANGE): eth2.2000: link becomes ready
[   27.350234] process '@/usr/bin/zerotier-one' started with executable stack
[   29.470689] br-lan: port 6(vethIsxPBP) entered blocking state
[   29.476468] br-lan: port 6(vethIsxPBP) entered disabled state
[   29.482472] device vethIsxPBP entered promiscuous mode
[   29.520713] eth0: renamed from veth1g5b7M
[   29.558102] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   29.564552] IPv6: ADDRCONF(NETDEV_CHANGE): vethIsxPBP: link becomes ready
[   29.571568] br-lan: port 6(vethIsxPBP) entered blocking state
[   29.577361] br-lan: port 6(vethIsxPBP) entered forwarding state
[   29.878858] br-lan: port 7(vethzdk0fh) entered blocking state
[   29.884639] br-lan: port 7(vethzdk0fh) entered disabled state
[   29.890634] device vethzdk0fh entered promiscuous mode
[   29.937707] br-lan: port 7(vethzdk0fh) entered blocking state
[   29.943490] br-lan: port 7(vethzdk0fh) entered forwarding state
[   29.978309] eth0: renamed from veth7OaZlz
[   30.050915] IPv6: ADDRCONF(NETDEV_CHANGE): vethzdk0fh: link becomes ready
[   30.851636] pppoe-wan: renamed from ppp0
[   43.826279] docker0: port 1(veth6250cc1) entered blocking state
[   43.832290] docker0: port 1(veth6250cc1) entered disabled state
[   43.838449] device veth6250cc1 entered promiscuous mode
[   46.423556] eth0: renamed from veth4330730
[   46.481672] IPv6: ADDRCONF(NETDEV_CHANGE): veth6250cc1: link becomes ready
[   46.489874] docker0: port 1(veth6250cc1) entered blocking state
[   46.495821] docker0: port 1(veth6250cc1) entered forwarding state
[   46.529298] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[   66.794991] TCP: request_sock_TCP: Possible SYN flooding on port 5000. Sending cookies.  Check SNMP counters.
[   94.469869] docker0: port 1(veth6250cc1) entered disabled state
[   94.476427] veth4330730: renamed from eth0
[   94.591912] docker0: port 1(veth6250cc1) entered disabled state
[   94.600511] device veth6250cc1 left promiscuous mode
[   94.605518] docker0: port 1(veth6250cc1) entered disabled state
[   94.800585] docker0: port 1(veth23868d8) entered blocking state
[   94.806562] docker0: port 1(veth23868d8) entered disabled state
[   94.812777] device veth23868d8 entered promiscuous mode
[   94.820955] docker0: port 1(veth23868d8) entered blocking state
[   94.826942] docker0: port 1(veth23868d8) entered forwarding state
[   95.553352] docker0: port 1(veth23868d8) entered disabled state
[   95.703530] eth0: renamed from veth87afa25
[   95.743873] IPv6: ADDRCONF(NETDEV_CHANGE): veth23868d8: link becomes ready
[   95.750941] docker0: port 1(veth23868d8) entered blocking state
[   95.756906] docker0: port 1(veth23868d8) entered forwarding state
[  106.072583] TCP: request_sock_TCPv6: Possible SYN flooding on port 5000. Sending cookies.  Check SNMP counters.
[ 3588.663946] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[44408.831180] br-lan: port 1(lan0) entered disabled state
[44408.837260] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[44434.230309] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[44434.238937] br-lan: port 1(lan0) entered blocking state
[44434.244183] br-lan: port 1(lan0) entered forwarding state
[47703.771367] pppoe-wan: renamed from ppp0
[47738.040041] docker0: port 1(veth23868d8) entered disabled state
[47738.048085] veth87afa25: renamed from eth0
[47738.166507] docker0: port 1(veth23868d8) entered disabled state
[47738.175657] device veth23868d8 left promiscuous mode
[47738.180720] docker0: port 1(veth23868d8) entered disabled state
[47738.364785] docker0: port 1(vethfb1e356) entered blocking state
[47738.370793] docker0: port 1(vethfb1e356) entered disabled state
[47738.376993] device vethfb1e356 entered promiscuous mode
[47738.384386] docker0: port 1(vethfb1e356) entered blocking state
[47738.390374] docker0: port 1(vethfb1e356) entered forwarding state
[47739.065556] docker0: port 1(vethfb1e356) entered disabled state
[47739.326272] eth0: renamed from veth0a77a23
[47739.366345] IPv6: ADDRCONF(NETDEV_CHANGE): vethfb1e356: link becomes ready
[47739.373379] docker0: port 1(vethfb1e356) entered blocking state
[47739.379340] docker0: port 1(vethfb1e356) entered forwarding state
[86348.391702] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Down
[86348.422739] br-lan: port 1(lan0) entered disabled state
[86365.861397] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[86365.870014] br-lan: port 1(lan0) entered blocking state
[86365.875277] br-lan: port 1(lan0) entered forwarding state
I also cannot force it, by disabling auto negotiation:
root@turris:~# ethtool -s eth2 autoneg off speed 2500 duplex half
Cannot set new settings: Invalid argument
  not setting speed
  not setting duplex
  not setting autoneg
  not setting autoneg
root@turris:~# ethtool -s eth2 speed 2500 duplex half
Cannot advertise speed 2500 duplex half
Is there anything I can do, or 1Gbps is the maximum throughput I can have with this setup?
There is no speed 2500 half duplex maybe thats the case
Good point @AreYouLoco, thanks for noting that!
As it didn’t worked with my first settings, I am now just exploring both sides, trying to understand what is causing this issue.
On Turris side, I tried as many things as I could, like trying to enable/disable auto negotiation, speed settings, and duplex mode (half and full). I am getting this “Cannot set new settings: Invalid argument” message with each of these settings I try to apply.
On ODI module side, there is a variable (LAN_SDS_MODE) with 3 modes that 2.5Gbps (theoretically) works. Any of these modes needs flashing this variable and rebooting the module. Every mode I flash gets downgraded to 1Gbps mode when router recognizes spf module and starts communicating with it.
I am starting to think now that it may have something to be with that rj45 1Gbps port that Turris “switches” while booting up (or, maybe, something with the driver itself).
So, is there anyone that could manage any other sfp module to work with more than 1Gbps total throughput in Turris Omnia?
There is one module, that delivers 2,5 GB/s, but not pure SFP but a SFP to RJ45 copper-adapter sold by Turris Team (officially supported). Haven’t seen any other module with 2,5 GB/s reported working yet.
Got it!
There must be some kind of signaling, or better hardware integration that makes that module to work.
ethtool device information below:
root@turris:~# ethtool eth2
Settings for eth2:
	Supported ports: [ FIBRE ]
	Supported link modes:   1000baseX/Full
	Advertised link modes:  1000baseX/Full
	Speed: 1000Mb/s
	Duplex: Full
	Port: FIBRE
	PHYAD: 0
	Transceiver: internal
	Auto-negotiation: on
	Supports Wake-on: d
	Wake-on: d
	Link detected: yes
root@turris:~# ethtool -i eth2
driver: mvneta
version: 1.0
firmware-version:
expansion-rom-version:
bus-info: eth2
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
root@turris:~# ethtool -m eth2
	Identifier                                : 0x03 (SFP)
	Extended identifier                       : 0x04 (GBIC/SFP defined by 2-wire interface ID)
	Connector                                 : 0x01 (SC)
	Transceiver codes                         : 0x00 0x00 0x00 0x02 0x22 0x00 0x01 0x00 0x00
	Transceiver type                          : Ethernet: 1000BASE-LX
	Transceiver type                          : FC: intermediate distance (I)
	Transceiver type                          : FC: Longwave laser (LC)
	Transceiver type                          : FC: Single Mode (SM)
	Encoding                                  : 0x01 (8B/10B)
	BR, Nominal                               : 1300MBd
	Rate identifier                           : 0x00 (unspecified)
	Length (SMF,km)                           : 20km
	Length (SMF)                              : 20000m
	Length (50um)                             : 0m
	Length (62.5um)                           : 0m
	Length (Copper)                           : 0m
	Length (OM3)                              : 0m
	Laser wavelength                          : 1310nm
	Vendor name                               : ODI
	Vendor OUI                                : 00:00:00
	Vendor PN                                 : DFP-34X-2C2
	Vendor rev                                :
	Option values                             : 0x00 0x1a
	Option                                    : RX_LOS implemented
	Option                                    : TX_FAULT implemented
	Option                                    : TX_DISABLE implemented
	BR margin, max                            : 0%
	BR margin, min                            : 0%
	Vendor SN                                 : XPON22100614
	Date code                                 : 221009
Maybe someone in Turris Team could help identifying.
Try and contact support via official email (see thread by @Pepe) or open issue via gitlab, their developers are not watching this forum.
Edit: and please report back here whether those investigations have a positive outcome/link the gitlab-thread.
Hi guys!
For anyone who maybe facing the same problem, or not, I have opened up an issue in gitlab, as follows:
2.5 GBps mode not being advertised/recognized
